Very 1st COUPE " 7-up " coming in Oct 09
                    1990 7-up 65,000 miles very very clean in and out. Look to get everyones  opinions on this idea I have, to convert the convertible back to a coupe. I am fully aware of all the work that is involved. what do you think?...........it would be the only one in existence. I would video and take pics throughout the whole process and save all the original parts etc.
In 91 and 92 there were over a 1000 made in that color in coupe form. Also note that the verts are actually built as coupes on line and then the top is removed, so technically you would be removing that one step!
I'm so confused...
I would think it too would be a ton of work but if you cut the top off a coupe and figured a way to install it on the 7-Up, it would be a show stopper and you would still get the nice weather top down option.
Yeah, I dont get it either.
I agree with some of the others though. You will need a donor coupe any way so why not just re-upholster it and add the wheels, which there are plenty of around on GT's. None of the back seat parts will interchange either to make it look right.
Your 7 up, preserve it, as it will always be worth more as is.
Down side to this, your 7UP will be worth a lot less, and to most after the mods, it will just be an Emerald green coupe with white upholstery. To 7UP fans it will be destroyed and to anyone else upon close inspection it will seem to them that the car was wrecked and the roof was replaced.
Hope you decide not to do it.
Jerry
