Just a PONY in the dark!
Hello again Bob and to all who visit this great site,
In the process of detailing my Triple White with q-tips
Bob, should I post pics here or send to you via email first?
I decided to take pics of the white wonder in the dark, some with the Las Vegas strip in the background. Seems to give more detail to the car than a sunny day due to it's color. Here is the link, so what do you think?
http://pg.photos.yahoo.com/ph/deanl250/ ... /my_photos
For Now,
Dean
For Now,
Dean
Just curious is that your A/C line routed to the front of the fan shroud / radiator?
Sorry for calling you Bob! I have a business associate with the same last name as yours and I guess Bob came to mind when I wrote this post, Again, my apologies.
Dean
No problem. I knew it must have been an honest mistake since we have communicated via email.
I like the shots at night. [B-)] Great contrast between the car and the background. It really makes it stand out. I agree with Roughnech, your interior looks great!
If you want me to add them to my pictures page, I will. I can just use the ones off of yahoo or, if you send me the original images, I can post them at a higher resolution, if you have it. I usually edit them to 800x600.
John
Thanks for the compliments from you and Roughneck, much appreciated. I will email you a few of the night pics and some taken during the day as well. I use a Sony digital cam that has resolution up to 1450x1280 and anywhere in between, but the file sizes are huge as the res climbs.
Roughneck, yes that is the A/C line running over the radiator shroud. I have looked at other 5.0's and the compressor is different than mine as well, so I called the ex-owner and she told me that due to the heat of the desert Southwest, the car was ordered with a heavy duty cooling package using R-12 instead of R-134. I put my test thermo in the blow vent and got a reading of 31 degrees and I tested it 3 times. So as it heats up here in Las Vegas I think that I will leave it be
For Now,
Dean
I do like the idea of routing the cold A/C line to the front around the fan shroud where the is some air movement. It probably helps a great deal in not picking up the exhaust heat from the firewall.
My first thought was that this compressor is an aftermarket, but I will check around the SSV website to see if there are any special service Mustangs that were set up like this.
Thanks,
Dean
PS to all>>> I will post how I made the top and interior so white. So stay tuned
I have had no luck finding an A/C setup like yours. :?: I checked out sspmustang.org thinking that the police cars may have had a heavy duty cooling system. I have found nothing that matches your system. Sorry I couldn't help solve the mystery. Anyway, enjoy the cool air this summer....
Can't wait to hear on how you get your interior so white!
